qtla9111's avatar
Jun 22, 2020
Replacing Thetford Toilet - Water Hose Help
We have a 12 year old TT and it appears we will be keeping it for another 10 years. It's 24ft long and has two slides, hard to find these days I think.
It has the typical plastic Thetford toilet and I got a super deal on a Thetford Porcelain Classica (non-electric).
I need a hose that has exterior threads on both ends. I bought exterior threaded connectors, clamps and a hose but the smallest connector I can find is 1/2 inch. It's still too big.
What is the standard size? Here in Mexico, I can't find a 1/4 but I can order it online.
Or, is there a ready-made hose for this connection?
Thanks in advance for your help.
  • Okay, thank you for your help and advice. I will order the necessary parts. I checked Home Depot here in Mexico and they don't have anything smaller than 1/2 but I will check plumbing supplies.
  • Had the same problem.IIRC,they're not pipe threads but straight machine type threads. Accidently found the perfect hose at Home Depot. It wasn't in the toilet supply section but hanging over in pipe fittings...
  • From the water source to the toilet. Both require external thread.
  • wa8yxm's avatar
    wa8yxm
    What is this hose for?
    My Tetford has two hoses.
    The "Supply" fitting is a 1/2 inch IPT. now the fitting on the toilet is a different size but there was an adapter in the box to 1/2 inch IPT.
    The rinser hose clamps on a barb.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
