- MrWizardModeratormeasure it, or look it up and get the dimension
it might fit in a TT, measure the space where your current fridge is
when we did ours, the 10cuft would not fit unless i modified the cabinet
but the 8cuft fit with room to spare - Chris_BryantExplorer IIThat's pretty big- an inch wider and 6 inches deeper than standard RV models. I'm not sure if a lot of rigs have an extra 6 inches of floor space in front of the fridge.
- CA_TravelerExplorer IIIFor dry camping this refer will use 77AH per day based on published energy usage so consider battery bank size and how they will be recharged (generator, alternator or solar). It also probably requires a PSW (pure sine wave) inverter vs a MSW (modified sine wave inverter).
- hbskiExplorer
True, but many absorption refers have more space behind them than this one requires. In fact this one could be installed with little space behind if the flue fan is retained to actively move air over the rear mounted coils.
Also the case is only 21" deep, the rest is the door and it is only that deep in the center of the curved door.
yup - definitely not for everyone - jpmihalkExplorerThat looks a lot like the Haier 10.11 cu ft residential fridge we replaced our Norcold with. It fit almost exactly into the space left after removing the absorption fridge and gives us 4 more cubic feet and a door where we can put a gallon of milk.
That could be a clue as to why they are not working correctly- specs give max of 1 inch clearance, with zero being preferred.Also the case is only 21" deep, the rest is the door and it is only that deep in the center of the curved door.
That's why you loose 6 inches, actually. The door has to be "proud" of the cabinet in order to open.
Don't get me wrong- that is a nice little unit. There are just some models that are easier to fit, that are 23.5" wide and a couple of inches shallower. - hbskiExplorer
It is the Whirlpool unit re-badged as Kenmore. - hbskiExplorer
Chris Bryant wrote:
....That's why you loose 6 inches, actually. The door has to be "proud" of the cabinet in order to open.....
Also true except the part about me personally losing 6 inches of floor ;) My refer "cabinet" is proud of the slide out it resides in, which will just be cut back to only hold the case, leaving the door able to open and me losing just an inch or 2 of floor (and only at the very center of the door).
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
