The Universal kit is for a 2932770015. You had the 293277001. That may be your problem. Since the Thermocoupler is putting out the required millivolts, the only thing left is the module board is not processing that signal to leave the Gas Valve open. This is from Dino boards website and seems to state the universal board will not work in your application. Doug
Note: The Mirco P-711 will not work to replace the 3850415-013 board found in Universal Power Board kits
# 3308741.002 (2-way) and # 3308742.000 (3-way). These kits change the gas valve wiring and DC element wiring
(in 3-way refrigerators only). Our 3850415.01 board will work to replace the board in both 2-way and 3-way kit.
