Ruler readings???
joelyn
14.17 in. What would that reading be on a ruler? 14 1/2--143/4 etc etc
piston length.
need to know how long this piston is... see 3rd diagram...
7 REPLIES 7
JaxDad
piston length.
Give a man a fish, feed him for a day, teach a man to fish, feed him for life.
Take the decimal portion only, in this case .17, and multiply it by a medium accuracy measurement, say 16ths. So in this case, 16 x 0.17 = 2.72. So that would be 2.72 / 16ths.
If thatโ€™s not close enough move up to higher accuracy units, for example, 64ths would be 64 x 0.17 = 10.88 / 64ths. So that would be 14 and 10.88 / 64ths.
DrewE
Given the comment "Please allow 0.5-1 inch difference due to manual measurement.(1inch=2.54cm)" in the listing, I'd call it about 14 1/8", more or less, and be prepared for it to be a little different.
Undoubtedly the original specication (which may not be precisely reflected in the stated specifications) was in metric units.
Lwiddis
X2, DFord.
DFord
Why aren't you selecting it by application? Find one that's listed for the vehicle you're going to use it on.
Don Ford
2004 Safari Trek 31SBD (F53/V10 20,500GVW)
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
BlueOx Aventa II Towbar - ReadyBrake Inertia Brake System
joelyn
perfect, thank you
Cameo_Phil
14 and 11/64 inches would be the length.
2002 Carriage Cameo F35CKB
2005 Chevy 3500 LT, CCLB 6.6L Diesel 4X4
Bobbo
piston length.
In order of decreasing accuracy, 14.17 inches is
14 11/64 inches (14.171875 inches)
14 5/32 inches (14.15625 inches)
14 3/16 inches (14.1875 inches)
Since that diagram appears to show the MAXIMUM length, I would not exceed it. Therefore, I would use 14 5/32 inches.
Bobbo and Lin
