RedRocket204's avatar
RedRocket204
Run Solar Circuit and Shore Power at the same time?
I'm about ready to install a smaller 200W solar system and have a question that I am finding multiple responses to. Do you run both your Solar circuit and Shore power at the same time?
Now, keep in mind I will be adding a + side 30A DC Disconnect Switch between the Charge Controller and battery bank. I already own the 30A DC Disconnect Switch and want it on there in the event I need to disconnect the Solar circuit from the battery bank. There will also be a 30A inline fuse between the Charge Controller and DC Disconnect Switch. That being I will have the ability to shut off the Solar circuit when connected to Shore power. But is that needed? Same would go for if I needed to run a generator for the AC.
Here is one source stating that it is no problems to run both at the same time: amsolar.com - Charge Controllers. Info is about 1/4 of the way down the page. But I've also read where you want to run those circuits isolated from each other.
Charge Controller is a Renogy branded 30A PWM. I've also recently replaced the TT battery charger with a Go Power! GPC-75-MAX 75 Amp 4-Stage Converter/Battery Charger.
Thanks.
