valhalla360
Jul 22, 2019Navigator
Your average roof air/con will pull 10-12amps continuous (much more for a second on startup).
As long as the breaker doesn't trip and you keep the other loads negligible, it should be fine if the connections are all clean and good condition.
Use the biggest shortest extension cord you can to minimize voltage drop.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
