Jul-01-2019 04:56 PM
Jul-08-2019 01:15 PM
Jul-08-2019 10:56 AM
NRALIFR wrote:dougrainer wrote:NRALIFR wrote:
I understand they make these neat things called “generators”.
Honda, Yamaha, Champion , etc.
I’d check into one.
Yes, if he had a truck. He has a Jeep. No place to store/mount the genset. Doug
Baloney. I could make a place for it. Probably quicker and cheaper than what he’s proposing.
This came out of my sick mind.
And this.
Don’t doubt a determined fabricator.
Jul-08-2019 12:04 AM
2oldman wrote:MrWizard wrote:No. It's 100ah @ 48v. I don't expect solar to keep up. The a/c is cycling.
Isn't that 400 ampHr of 48v, which is equal to 1600 ampHrs of 12v
A/C using 1200w the 800w of solar is Not going to keep up with energy use
1/3 of the needed energy will come from the batteries, but You have a surplus of battery power
The OP does not
Jul-04-2019 09:21 AM
The OP does not
Jul-04-2019 09:17 AM
Jul-04-2019 09:02 AM
Jul-04-2019 06:10 AM
Jul-03-2019 01:37 PM
I’d check into one.
Jul-03-2019 11:28 AM
Jul-03-2019 11:06 AM
I’d check into one.
Jul-03-2019 10:41 AM
Jul-03-2019 07:54 AM
StartingNewChapter wrote:
I am considering buying a 3000 watt inverter for my travel trailer. I would like to run my air conditioner whiling driving to my destination. My hope is that short stops for lunch can be accomplished in a comfortable trailer. The specs on my 20 amp air conditioner states is uses about 2700 watts to start then 1300 to run. I have 270AH batteries that I hope will supplement the startup power needed. I am wondering will my alternator on my Jeep Grand Cherokee provide enough power to run the tow vehicle, run the air conditioner and charge the Jeep and trailer batteries? I could not find any definitive answers from Jeep.
Jul-03-2019 07:50 AM
MEXICOWANDERER wrote:
The proper way to do this is way way way too advanced to make it practical.
1st LEECE NEVILLE 260-amp alternator READ 260+ amps
2nd A nightmare of mounting brackets that have to be ABSOLUTELY straight and true
3rd Drive belt or pulley changeover to drive 10 horsepower. $$$$$$$$
4th OO -
2/0 cables from alternator output studs through 200 amp breaker under chassis, sheathed in protector tubing to a pair of one contact 200 amps truck and trailer big rig sockets. NEGATIVE must be done the same way -- 2/0
Then straight to ANOTHER breaker then tied directly to the batteries that feed the inverter. Not straight to the inverter as an isolated power feed. Have problems and a flickering isolated/dedicated feed line to the inverter it will fail the inverter sure as hell.
How do I know all this?
A very wealthy customer had me and a precision machine shop do it thirty years ago. Brackets and pulleys alone cost nine hundred dollars. And the machinist ****** about the number of hours. It turned out to be an almost four thousand dollar modification. thirty years ago. He paid eleven hundred dollars for the alternator alone.
And I swore NEVER AGAIN.
After fifteen or twenty trouble-free years I lost track of the owner.
Ridiculous.
Jul-03-2019 06:55 AM
Jul-03-2019 04:40 AM
cpaulsen wrote:
Why run the trailer ac going down the road?
