chiefward
Nov 22, 2013Explorer
RV Plumbing Pipe
I;m going to reroute the galley tank discharge to the black and grey water discharge pipe. Is the rv black pipe the same as Home Depot white pipe? If not, where can I get the black pipe?
ScottnSherrie wrote:
White is PVC and black is ABS. They can be coupled with the correct fittings or rubber couplers. Since you asked such a basic question, I suggest you do a lot of research before you tackle this and get some help from a friend with plumbing experience.
