โNov-22-2013 03:09 PM
โNov-24-2013 08:45 AM
chiefward wrote:Puttin wrote:
Chiefward,
Just curious, are you eliminating the gray tank altogether? In other words, why are you doing this mod?
Thanks
My galley tank has a separate discharge point and I want to combine to only one grey,black,galley discharge point. When I get to a dump station, I don't want to hold up people dumping from two locations. I just bought a 2004 Dutchmen and in the process of "modding" it to fit my needs. This is just one of several modifications I plan to make.
โNov-24-2013 05:17 AM
Puttin wrote:
Chiefward,
Thanks
โNov-23-2013 03:17 PM
โNov-23-2013 07:32 AM
โNov-23-2013 05:48 AM
Huntindog wrote:chiefward wrote:
I;m going to reroute the galley tank discharge to the black and grey water discharge pipe. Is the rv black pipe the same as Home Depot white pipe? If not, where can I get the black pipe?
On some TTs the black ABS is a odd size. Not available at Home Depot etc. I got mine from a RV parts supply business.
It's been a few years since that project, so I can't recall the size. I also don't know how widespread this is in the industry.
โNov-23-2013 04:07 AM
ScottnSherrie wrote:
White is PVC and black is ABS. They can be coupled with the correct fittings or rubber couplers. Since you asked such a basic question, I suggest you do a lot of research before you tackle this and get some help from a friend with plumbing experience.
โNov-22-2013 06:25 PM
chiefward wrote:
Thanks for y'all quick response. I just didn't remember see the black ABS at HD. Will do a search at my HD for ABS. ( I didn't know what it was called.)
โNov-22-2013 05:39 PM
DutchmenSport wrote:
They are the same size. Last Spring I had to replace the p-trap under the bathroom sink. It was the same size as the white p-traps used in your home. You can use the white.
โNov-22-2013 04:40 PM
โNov-22-2013 04:20 PM
โNov-22-2013 04:08 PM
โNov-22-2013 03:37 PM
โNov-22-2013 03:27 PM
