dclark1946's avatar
dclark1946
RV radio mast antenna grounding for AM reception
This is a followup to my original post about no AM radio reception in our new KZ Spree due to the TV antenna not supporting AM.
I purchased an internal car radio antenna from West Marine which is essentially 40 in. of wire attached to a coax cable feeding a Motorola connector that mates to the antenna jack on the back of the radio. This gave good FM reception and some AM reception for strong stations. I also learned a lot about RFI generated by the converter and other appliances.
I now have a RV 30 in. mast radio antenna like our previous TT antenna and have started running some tests with it before it is permanently mounted on the roof. This antenna comes with about 9 in. of metal braid with a ground lug attached. In my initial testing it appears that that gnd connection improves AM reception even if only connected to a nearby aluminum ladder. I have not figured out how to get frame ground to the lug yet without running about 8 ft. of wire to a known ground point .
My question is where are you supposed to pick up ground within 9 in. of the roof where the antenna is to be mounted? Also does anyone know if the antenna cable shield becomes grounded when it is connected to the radio antenna jack or is the shield part of the connector isolated from 12V ground?
  • Good one, a head scratch-er.
    You could capture a ground from an AC device but a user should have a torroid or other filter to keep the nasties at bay. An alternative would be to run the ground back with the antenna wire to capture ground near the radio. How much better was the reception with ground accomplished?
  • wa8yxm's avatar
    wa8yxm
    I would just use the ladder. then if you feel the need ground the lower end of the ladder to the frame.
    The reception without the antenna gnd wire connected to the aluminum ladder had obvious white noise but you could understand the audio so I had probably a S/N ratio of 5-10 dB. With the gnd wire touching the ladder the white noise was just about undetectable.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
