Gdetrailer
Oct 06, 2022Explorer III
nickthehunter wrote:
It's called "Duct Board"
Clicky
See the problem with "Duct board" in a RV that I circled in red?
1" is the thinnest I seen on that first page of the link.
Unless you can find thinner ductboard than 1" wall it will be useless in a RV ceiling as it would only give about a 1" inside dimension.. That would be like trying to drink your coffee through a coffee stirrer (it can be done but at a cost of efficiency and not worth the hassle).
For duct board to work reasonably, it would have to be very thin, not much more than 1/4" wall which would take 1/2" of the open framing dimension the OP has to work with.
Thin ductboard also has a bad habit of sagging unless it is fully supported which is what the OP is fighting with..
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
