BFL13
Apr 13, 2019Explorer II
"The converter amps to generator watts are based on the recommendation of others for PRogressive Dynamics 9200 serie converters. they tell me that a Honda 1000 can only handle a 60 amp.. I know a Gernerac 1000 (True 1000 watts) can power a 9180 with charge wizard but I'm told a HONDA can not if the batteries are low. So since thi is a 900 peak (not 1000) I downgraded one converter from those. It might run a 60 but it would be running at maximum capacity."
Using your rocket science, you will note that for output of 45 amps at 14.6 volts (657w) you will need input of 9 amps x 120 volts (1080VA).
When you try to do that 1080 with a 900 peak gen, your rocket will be a damp squib.
"They" say that a Honda 1000 can "only" handle a 60 amper? They must have gone to the same rocket science school you did. A 55 amp converter with the usual 0.7 PF pulls 11 amps at 120 volts (1320VA)
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
