road-runner
Apr 13, 2019Explorer III
pnichols wrote:Another ultimate solution is a charger that lets you set the maximum amps it will draw from the AC input. I use a prosine 2.0 for exactly this reason, just for the charger. Haven't used the inverter yet. I could use the inverter, just haven't needed to yet.
I guess the ultimate would be a charger with an adjustable output voltage, so that you could adjust downwards it's output voltage a bit under 14.XX volts to the point where a small generator doesn't quite stall from current overload. This would allow a small generator to be used for partially charging of any size battery bank between full charges via some other method. ;)
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
