โNov-06-2015 01:43 PM
โNov-15-2015 09:27 AM
Boon Docker wrote:Yah, thanks. Looking forward to it - and smaller wire!
Sounds like a pretty nice system.
โNov-15-2015 09:02 AM
โNov-15-2015 08:48 AM
Boon Docker wrote:Hehe.. sorry, just waiting for my inverter to arrive. Should be here Tuesday. Company confirms I must have at least 20 volts on the terminals for it to work.
i quess we will never know.
โNov-15-2015 08:37 AM
โNov-14-2015 09:28 PM
2oldman wrote:
I asked about putting 2 24s in series before buying the Schauer. Iota said no,not with the 24v smart charger I have.
I will hook up 48v of battery and report back. Thanks.
โNov-06-2015 05:12 PM
โNov-06-2015 04:43 PM
โNov-06-2015 04:03 PM
RoyB wrote:Check my profile.
Where are you going to get 48VDC from..
โNov-06-2015 03:33 PM
โNov-06-2015 03:20 PM
2oldman wrote:Gdetrailer wrote:Yes it is. Supposedly will never overcharge, and has both a flooded and AGM setting.
Is it a "smart" charger?
I would readily agree with you, except for the part in the manual about not using it as a power supply for a long time. With that in consideration, does that change anything?
โNov-06-2015 03:19 PM
โNov-06-2015 03:06 PM
smkettner wrote:2oldman wrote:Do you have a 24v converter? I would get identical and let them run in series.Gdetrailer wrote:Yes it is. Supposedly will never overcharge, and has both a flooded and AGM setting.
Otherwise I would get a 48 volt IOTA.
48 Volt models also available. Call 888-828-1893
Specifically designed to run with or without a battery as a power supply.
Don't forget the IQ controller.
โNov-06-2015 03:02 PM
โNov-06-2015 02:28 PM
