Grit_dog
Apr 28, 2023Navigator
StirCrazy wrote:
There is a reason they are welded on from the factory. If you're going to keep with the bolts, get actual bolts and lock washers and nylock nuts and put them on. those screws will vibrate loose as you drive.
What he said.
And while it seems unlikely, that they would just vibrate loose, self tappers do. Even with thread locker. I zipped a new step on the frame of my snomachine trailer with self tappers.
Even with threadlocker they came loose repeatedly.
There’s room to bolt them up. Nylock, lock washers, loctite etc. whatever combo you like.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 16, 2025
