KD4UPL
Dec 08, 2021Explorer
I wouldn't mess with little 125 watt panels unless that's all you can make fit. Larger 300 to 400 watt panels are much less expensive, easier to find, and easier to wire up.
If you're planning on even a medium size system I would go 24 volt minimum but 48 volt would be the best choice. You can just use a 48 volt to 12 volt converter to keep your factory 12 volt systems powered.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
