murraymcleod's avatar
murraymcleod
Shower cycling hot and cold! Pests in heater vents??
We took our new (to us) 2003 27' Itasca Sunova camping for the first time this past weekend for a shake-down trip, and all systems seemed to work fine except for the shower temperature! When using the shower it was hard to get a stream of constant temp water. It seemed to pulsate with hot, then cold, then hot again. This seemed to have some correlation to the water pump cycling on and off, but not entirely sure as I didn't want to waste water. Is there a pressure regulator somewhere to even out the hot and cold flows so that one isn't stronger than the other when the pump goes on?
And the only other issue was that our Jack Russell terrier (Teddy) seemed fixated on "something" in the heater vents (the one in bedroom, and the one in the living area up front). He would stare into the vents and whine/bark as if he knew something was down inside the heater venting! There are no signs of any rodent problems, and we used the heater a lot so I assume anything in there would have been cooked! Is there an easy way to clean out the heater ducting just in case?
Of course this dog is known to be a bit crazy, so it may have just been his imagination, or maybe he heard sheet metal expanding/ contracting with the heat flow!
Thanks!
