12th_Man_Fan's avatar
12th_Man_Fan
shower door handles
I have the shower with the three glass sliding doors and a handle on each end.
The handles on these doors get knocked of nearly every trip. I have used every kind of epoxy that I can find.
Does anyone have a permanent fix for keeping these handles on the glass?
Thanks in advance for any suggestions.
  • I have had great luck bonding different types of materials such as glass and metal together with Goop All Purpose
    If you can clamp it for 24 hours it seems to work on anything.
  • Do your handles have a small hex head bolt that snugs down through or onto the surface of the glass? If not perhaps seek newer ones that do that as then you have some mechanical force. In addition some double sided tape may help. I had the same issue as you until I got the bolts that snug onto the glass with rubber gasket also installed
  • I tried different adhesives, but finally used JB Weld. So far so good.
  • Not sure how easily they are being knocked off, but if the doors are being slammed back/forth, may be better to reattach handles, than replace the glass.
    Jerry
  • DrewE's avatar
    DrewE
    Maybe rear view mirror mounting adhesive?
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
