Shower hose fittings problem
kejones62
I have a Jayco travel trailer. I needed to replace the shower hose, so I bought one off of Amazon. I can screw the 'head' end of the hose onto the head, no problem. However when I go to screw the other end onto the faucet diverter, it goes on maybe a half turn and sticks. At this point the internal mating surfaces are not pressed together - the hose rattles loosely in the nut - so it is not a watertight seal. I've played with this for hours, although the fittings look the same, and the thread pitch is the same, the fittings won't go together. Has anyone had this issue before? Is there some adapter I need? I thought these things were all 'universal'.
BTW, this is the hose I bought. Cheap enough to just get a different one, but I don't know if that will help. Blissland Shower Hose
18 REPLIES 18
kejones62
if I grab a 1/2 NPT male, I can screw it into either end of the hose. However on the end that goes into the diverter, I can only get it a few turns before it starts to tighten. The threads are definitely 1/2"-14, but maybe the taper is off? I can actually get it more than 1/2 turn onto the diverter - that was a mistake - but I can't get it tight enough to mate the washers. The thread get tight before the washers mate.
wopachop
Both ends appear to be the same size.
Does the shower head screw into the other side?
It it only goes 1/2 turn it sounds like a difference in threads or a bad thread job.
joelc
Go to a hardware store and bring your head (shower head, too). Let them take a look so you can purchase the right one.
agesilaus
Odd every shower fitting I've seen is 1/2 inch pipe thread, 1/2 NPT.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
