nomad_289's avatar
nomad_289
Side Seam Sealing prep?
What preparation is recommended prior to applying seam sealant on vertical surfaces?
Maybe(?):
1. Cut old caulking away with box knife.
2. Scrape remainder with plastic scraper.
3. Clean with acetone.
Sounds like a-lot of work, but I don't trust dealerships to do it "right". Advice from those who have done it? Thanks.
Plan to use:
Proflex RV sealant
White or Clear?
  • Thanks Guys.
    I'll use the 3M Adhesive remover and White to hide the seams.
  • That's the way I do it- I use 3M adhesive remover- available where they sell auto paint. Removes silicone residue as well.
    If the rig is white, I would use white.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
