Colo_Native's avatar
Colo_Native
Silde adjustment
I have a through the frame Slides they are both tight to the top and 1'to 1 1/2" out at the bottom I have looked at the Lippert manual for adjustments but when I adjust the can the problem gets worse is there a way to adjust the level so it is more or less plumb to the sidewall. The slides are tearing the blub seals at the top and barely touching the bottom. I have searched you tube but nothing. I am thinking I made need to lower the slide from the frame bracket. Thanks for the help
  • "Both in and out the top will hit first at least on mine."
    Ditto.
  • wa8yxm's avatar
    wa8yxm
    "Through the frame slide" Do you mean rack and pinion? (Longed toothed rail under the slide) they are designed so the top hits the seal first as the power is at the bottom.. Both in and out the top will hit first at least on mine.
    There is very little adjustment.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 07, 2025
