Since Technical Resources Is Unresponsive...
MEXICOWANDERER
Garmin 010-01539-01 DriveSmart 50LMT GPS Navigator $85.00 refurbished
It says it has voice instructions
But I have bad hearing
How LOUD does the volume adjust to? I'll try and give an example.
With all windows open on a busy city boulevard
Could a "normal" person understand the commands?
That being said it is supposed to have an earphone jack. Does something like a 12 volt powered amplified speaker exist that could plug into the jack?
With my budget eighty five dollars is a chancy roll of the dice.
Thank you
16 REPLIES 16
fj12ryder
I wear hearing aids and the Garmin Nuvi 2856 is loud enough to hear over the Cummins in our 2001 Dodge. However it doesn't have an earphone jack. Some of the newer ones don't have one, so you might double check to make sure the one you're looking at has the earphone plug.
Howard and Peggy
"Don't Panic"
SidecarFlip
I have a Magellan and it's a nicer unit. Same price and has a dash cam too and...I can hear it just fine.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
