I have 2 hydraulic slides. The bottom of the bedroom slide will creep away from wall when in closed position. Takes a while, like week or more to do so. I have a Lippert pump, and I know it has a s...
Solenoids actuated valves are on/in the pump. Do you see wires besides the motor wires?
My Lipper pump leaked and the motor stopped running. Right at the 2 year warranty and when I pointed out the 3 design flaws with the pump they sent me a new designed replacement.
The leak needs to be fixed in addition to the slide drift. Have you tried the manual procedure for operating the slides? If not that will reveal the second design flaw if your pump is like mine.
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
