I have 2 hydraulic slides. The bottom of the bedroom slide will creep away from wall when in closed position. Takes a while, like week or more to do so. I have a Lippert pump, and I know it has a s...
4 hoses suggests the valves are there also, ie a hose to each end of the hyd cyl, 2 slides and 2 cylinders. Somewhere there are valves that control the fluid direction for each slide ie in/out. When closed the slide will not move unless there is a leak. Check the hoses and hyd cyls to make sure there are no leaks anywhere.
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
