Slide out power.
Skip___Jackie_T
I have a 38 ft. Jayco 5'er. Thinking about going boondocking and wonder what kind of generator wattage it will require to push em slides out and pull em in. Anyone that had this experience, thanks for you help.
Much obliged, Skip
Moved to Tech Issues forum from Towing.
9 REPLIES 9
Skip___Jackie_T
Well friends, here I am again. I fixed the problem and so thankful to all that responded. I had checked all the fuses and they were all good. The battery is brand new and fully charged but I found an inline fuse near the battery in the battery compartment and that darn 30 amp fuse was blown. Now I feel like a RV mechanic, (well almost).
This is a great web site and just full of nice people.
Skip and Jackie Tatum
Timberlake N. C.
Skip___Jackie_T
Thank all who responded and I will check all the things you have mentioned. I have always got good advise from my RV buddies and much oblige to you all.
Skip
Ron3rd
The OP has some sort of problem; all slides should work on 12v.
Equilizer Hitch
Honda EU2000
mbopp
Something's not right - slides should work on battery. Most manufacturers say NOT to run a slide on just the converter which is what you're doing now.
2019 F250 XLT Supercab
Just DW & me......
powderman426
Mine was acting like that, and we found the wall switch was making contact but not as good as it should and with the converter running it boosted it enough to make it work.
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
skipnchar
My guess is you have a blown fuse on the slide so it will only move by getting 12 volt power from the converter. Slides are usually wired directly to the battery with a fuse in between and MANY will not work from the converter 12 volt power at all.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
dbbls
I doubt your battery is fully charged. Slides are 12 volt and your battery may be shot.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
Skip___Jackie_T
I thought the slide was 12 volt also but I checked them a bit ago and the slides work in and out fine with AC plugged in but when I unplugged it I got no movement. The battery is fully charged. Thank you for responding.
Skip
joelc
Don't know what type of rig you have but on both my 5th wheels (one past and one present) both operated slides were 12V.
