wa8yxm
Nov 28, 2021Explorer III
The best advice I've seen comes in parts in this case.
1: Disconnect battery negative cables before doing anything else (Both main (Chassis) and aux (house) on a motor home
2 If there are electronics NEAR where you are welding.. Unplug and remove be sure to mark so you put 'em back properly
3: Make sure you have a SOLID chassis ground on the welder lead No paint. NO rust. Bare shiney metal
Finally: Standard precautions taken any time you weld
on my rig I had a bracket break as well however it was removable so they welded up the new one on a bench then bolted it back in place WAY better than the oem .
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
