sueray23's avatar
sueray23
Slides, Awning,& Landing gear.
I have a Keystone Cougar 37' fifth wheel. The control panel runs lights ,holding tanks water heater, 3 slides,& awning. A outside switch for the landing gear. Everything works but the slides, awning, & landing gear. The only way I can move the slides, awning, & landing gear is with the remote control. Can anybody help me.
  • I must have missed the post where he said he had the LevelUp system.
  • This is a classic problem with the LevelUp brain. The solution is pretty easy. I posted it, with pictures, on an earlier topic about the same subject. LevelUp Brain Fix
  • I checked all the fuses and I turned the remote off, and still nothing. I will pull the control panel and check for power. Thanks for the help.
  • Blown fuse on the lead from the control board to the switches?? The control board supplies power to all the manual switches.
    Yes, it takes precedence over the switches.
  • In some cases the remote control takes president over the manual switches. Can you turn the remote off?
    A friend of mine had this problem and he could not turn his lights off by switch if he had turned it on with the remote.
    Does this make any sense?
  • Well, you know they function with the remote control center. Now you need to pull the panel and physically check the switches there and see if they're getting power, and if not, find out why not. Have you checked for blown fuses?
  • Lots of remote control board issues over the last few years. IMHO a remote control is a big waste of time.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 19, 2026
