โApr-07-2021 03:18 PM
โApr-08-2021 12:29 PM
FWC wrote:red31 wrote:
controller eff of mppt is a real loss of power via heat sink, esp cheaper models!
mismatched or in low power conditions.
While I can't speak to some of the off brand/cheaper models of MPPT controllers, for the reputable ones (think Victron, Morningstar) the conversion efficiency is really pretty good. In the figure below, the orange line is a Morningstar MPPT controller, they don't say which controller the blue line is. In either case the power lost to heat is much lower than the power gained by MPPT and reduced wire losses.
โApr-08-2021 09:29 AM
โApr-08-2021 09:06 AM
โApr-08-2021 08:58 AM
BFL13 wrote:It's certaintly relevant when comparing 3x100W vs 300W. Both panels panels lose about the same amount of power.
The knock that PWM wastes power has no meaning because the panel goes to battery voltage, well below whatever panel voltage is at the time. Watts are of no interest--it is all about the amps.
โApr-08-2021 08:52 AM
โApr-08-2021 08:23 AM
โApr-08-2021 08:10 AM
BFL13 wrote:There's very little downside to over-panelling.
I agree with over-panelling a bit with MPPT to get a bigger AH haul over the whole day
โApr-08-2021 08:09 AM
โApr-08-2021 07:53 AM
โApr-08-2021 07:22 AM
โApr-08-2021 06:33 AM
โApr-08-2021 01:32 AM
wanderingaimlessly wrote:
I'm not apparently making my question clear.
To take a different tack,
To charge a 300 Amp hr, 12 volt battery bank
Would 3, 100 watt ,solar panels such as
renogy 100 wired in parellel,
provide a substantial upgrade, or downgrade as compared to a single REC 325
The gain or loss due to voltage difference is my question.
Or is this a case of 300 watts is 300 watts,,voltage be damned?,,
โApr-07-2021 05:21 PM
wanderingaimlessly wrote:Yes you got it!
โApr-07-2021 05:15 PM
FWC wrote:
300W = 300W. Now we will argue all day about one way you could get 310W and the other way is 290W, but in the end it doesn't matter, the differences are small. The 325W panel will mate nicely with a Victron 100/30 or 100/50 MPPT charge controller. . Go with the 100/50 if you think there is any chance you may want to add another panel in the future.wanderingaimlessly wrote:
