โApr-24-2022 11:02 AM
โJun-06-2022 06:16 AM
โMay-31-2022 12:13 PM
Cptnvideo wrote:Itinerant1 wrote:Cptnvideo wrote:
"Lugging around 130# or more generator doesn't sound like fun."
My 3500 watt Harbor Freight inverter/generator (which I rarely need or use) is always in the truck bed. Its heavy, but I only have to move it to the tailgate, so weight is not much of an issue.
Your solar/ battery system is very similar to mine and in 6 years of continuous boondocking I have never felt anything larger than 2-2200w generator was needed, whether throwing a hold over charge or running the AC even at 7-8,000' elevation on a hot day. I suppose having the hydrid inverter/ charger has its advantages though.
If a person had the large generator before hand and don't mind carrying it in the bed of the truck no reason to get rid of it. Having options for different camping....glamping needs makes roughing it easier. ๐
โMay-31-2022 12:08 PM
โMay-31-2022 12:05 PM
โMay-31-2022 11:54 AM
โMay-31-2022 11:27 AM
โMay-31-2022 07:32 AM
โMay-31-2022 07:09 AM
MFL wrote:2oldman wrote:
That one generator will be working hard and LOUD running it, and you'll have a heck of a time running anything else, including your converter.
^^This...just not the right tool for the job. If you want to run the air, and other things, better to add/connect second generator, or sell/trade the 2200 and purchase a more capable single.
Jerry
โMay-31-2022 06:36 AM
Sophia11 wrote:Bobbo wrote:
Is there an extended run tank for the Yamaha like there is for the Honda?
Yes, there is an extended run tank for the Yamaha. The Yamaha extended run tank has a capacity of about 35.4 gallons. The tank has a threaded locking cap, which makes it easy to install or remove the tank for refilling.
โMay-31-2022 03:52 AM
โMay-26-2022 07:25 AM
Sophia11 wrote:
I have use Yamahas generators its far better than Honda
โMay-25-2022 03:54 PM
โMay-04-2022 01:59 PM
RLS7201 wrote:theoldwizard1 wrote:time2roll wrote:
The $20 kits are generally an additional start capacitor. These work great on the older models that had none. Most of the newer models already have this feature and the kit would have limited effect.
Without getting into the electrical engineering of AC motors, a larger or an additional starting capacitor could making starting current draw worse !
EasyStart by Micro-Air is a highly recommended soft starter.
Please, if you would, get into electrical engineering and explain to us how additional capacitance will raise AC motor starting current line draw.
Richard
โMay-04-2022 11:49 AM
