mlts22's avatar
mlts22
Dec 16, 2015
Small fans for the area under the solar panels?
As a side note, my plans are sidelined for bit due to a contract abruptly ending... found permanent work, but that's not until January, pretty much.
However, for a custom solar install which will be used in the Texas heat, I wonder about having a water-resistant, 5V, fan for having air circulation underneath the panels. The Texas summers tend to be hot, humid, and very little in the way of breezes, so having air be directed underneath the panels, so the only real heat transmission between the panels to the rig is via the mounting brackers. Blowing air on the back also reduces the temperature of the panels, increasing efficiency.
There are 12 volt models which push 100 cubic feet per minute... for the cost of 2-3 amps... but hopefully I can find some five volt, water resistant models that can push a fraction of that, for 60-100 milliamps of current use. Since there isn't much air to be moved between the panels, even 6 CFM would move a good amount of air. It might be that the added energy gain by the cooler panels would more than offset the current use by the fans.
When on the road, this isn't an issue, but when parked or the rig is in storage, the airflow should help things.
Think this is worth looking into, or would it not move enough air to help significantly with panel energy gain or cooling?
  • ktmrfs's avatar
    ktmrfs
    I think You'll find that the current draw of any fan capable of lowering temps will be higher than any current gain you get from higher Vmp and Higher Imp.
  • You might gain something from fan cooling of the controller. I saw somewhere that you gain more in controller output than you lose running the fan when it is hot near the controller.
  • I think if you look around that any 12vdc box type fan is ~60-300ma, not Amps.
    Check out all electronics.com for fans
  • Radiant heat would be infintesimal. I live where it is very warm and humid. Shade is key. This is where an inexpensive IR gun pays off. A couple of readings - a big surprise (to you) then move on to doing stuff that might actually work (like shade the SIDES of the rig).
  • I can always turn on my fan. :B
    ie Raising the panels helps with the air circulation and helps to avoid shadows.
  • I too made the nearly the same brackets but kept a uniform height with each bracket. I raised my panels a min of 2 inches as most of our boondocking is in the SouthWest heat of 90+ degrees in the summer and to clear a couple of vents. Never had any problems from heat or wind.
    rocmoc n AZ/Mexico
  • I also think that the fan idea would waste more power than it will collect.
    If you will be in one location for more than say 10 days, it might be worthwhile to tilt the panels to the south, and that will put them more up in the air, and any heat would be conducted away as the air behind the panels are heated by the 140F panels, and that will thin the air, lighten it, and move it upward on it's own.
    Personally right now, I would rather save damage to my roof by not tilting them, and be satisfied with the output they are putting out. I barely need all the power they produce now anyway. IF you have hookups to run the A/C, then you will not need a lot of 12 volt power. Just shut off your converter/charger, and enjoy all the free solar power to run your lights, pump, ect. for free. If you do not have 120 volt power, good luck with the Texas heat. I lived in Mesa AZ one summer, and could not have done it without my A/C keeping my bedroom a 'cool' 80F at night.
    It is much cheaper to install a extra panel than to risk damage from climbing on the roof to tilt them, and a lot easier too! And you will shade more of your roof too! Benefits all around!
    SunElec.com
    I used mounts that keep the panels about 1" off the roof, so they actually keep the roofing membrane cooler under the panels, than the exposed roof temperature.
    Here are some pictures of my solar mounts, when it rains they are under the panels, so the rain is not directly over the screw holes. Also it makes it more difficult to remove without the proper antitheft Torx screwdriver adapter.
    Golden_HVAC wrote:
    rickthescot wrote:
    Sounds like a great idea. I guess asking for pictures again is not going to persuade you though. We are visual creatures and I don't think 1000 words will accomplish what one image will. You can do it, just one pic.
    More pictures that I took a few days ago to post pictures of my solar panels, and their mounts. Some pictures are really close up pictures of the solar panel mounts, and give a clear picture of howrough the surface is.
    Golden_HVAC wrote:
    Hi,
    This is my front pair of panels. 120 watt mounted on a curved roof, 102" wide.
    This is the mount it is held on with three rivets into the frame, and then the bottom half is 6" long aluminum, (Home Depot 2" angle aluminum) with nutsert in the upper piece, bolt you can not see from the outside edge pointing inward.
    This picture shows the bigfoot panel mount sold by RvSolarElectric for $35 a set back in 1994. I wonder what they cost today?
    This picture shows the panels tilted while I was working on the roof.
    Fred.
    If you google Nutsert insert tool, you will see several videos of people installing nutserts, and they are easy to install, difficult to remove, easy to use to install, tilt or remove the panels.
  • I think you'd find that the radiant energy (heat) from the Sun on the module can't be hardly impacted with a fan.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
