StewB
Mar 17, 2015Explorer
Solar 30 Charge Controller?????
Is anyone here familiar with setting up a Solar 30 Charge contoller?
Not knowing much about this stuff, and having directions converted from chinese, I could use some input on setting one up.
What should the "ceasing charging voltage be?
What should the "recovery voltage" be?
I would assume 'low voltage protectin point " is the lowest you want the batteries to go before the controller cuts off the load? This must only be the load from the load connections on the controller itself?
Is "ceasing charging voltage" the float setting?
I am not using the load connections, just the battery connections to keep some batteries charge up at my cabin.
Any input on setting this thing up would be appreciated.
Thanks very much
Stew
Thanks very much
Stew
