52markwilliams's avatar
Jan 06, 2015
Solar Cells charging batteries
I'm not any electrical engineer.
I have a new fifth-wheel with all the bells and whistles.
I have a 3000 Watt solar panel on the roof.
Question: Will the solar panels keep my batteries charged while in storage ? Thanks
  • Mark
    How large is this solar panel
    300w is about 5 ft by 6 ft
    30w about 18 inches by 30 inches
    3000w about 50 ft by 60 ft
    3 watts will set on top of the air conditioner
  • Lynn0527 wrote:
    CA Traveler wrote:
    Lynn0527 wrote:
    I had exactly the same question as my RV is parked on my driveway (I have 100W solar panel) and I live in Canada but I was told a trickle charger would work better and that is what I have now. Cost me about $40.00 and I haven't had any problems even in the coldest weather.
    Great option when you have AC power. The rigs charger will/should do the same but may use more power since typically there are some loads but it all depends upon what kind of disconnects you have.
    Yeah, I just learned that today. I will probably take the trickle charger back as now I was told if I plug in my coach battery and leave the disconnect switch on, both batteries will keep a full charge.
    I am new to this and it wasn't in my owners manual. Sorry, back to the solar question, didn't mean to hijack OP.
    Hold the phone - old saying.
    With a voltmeter verify that both batteries will be charged, not all chargers charge the chassis battery. You can get an adequate voltmeter for $5 at HF or even a free one.
    Post your charger mfg and model number. Forum members will very likely advise you about the charger. Not all chargers are "good 3 stage" and not all are good at maintaining the correct float charge. What you have may be just fine but it doesn't hurt to find out.
    A new thread with appropriate title might be helpful.
  • Hi Lynn,
    You were misinformed.
    Good luck.
    Good luck.
  • For 30W maybe if all loads are off. Off as in full battery disconnect except for the solar connection.
    I doubt you have 300W but maybe. What is the controller mfg and model number? Solar panel model?
    Just barely.
    Will solar keep your batteries up in storage? Yes as long as there isn't more draw than the solar puts out.
    I'm not sure but I believe a 3000w panel would be the size of a house, so I bet it's between 30w (good for storage duty) to 300w.
    Congrats on the new camper.
Having RV issues? Connect with others who have been in your shoes.24,277 PostsLatest Activity: Jul 01, 2025
