BFL13
Aug 31, 2018Explorer II
Yes about the Tri. Doug said (shouted!) an inverter/charger is different from a converter in that all 12v loads come from the battery and the charger part only recharges the battery.
So I can't figure out if that means loads do not come first as with a converter or controller, which would make the Tri see net amps in that case.
