CA_Traveler
Nov 15, 2021Explorer III
OkieGene wrote:One option is to start learning now with a portable battery, solar panel and of course your radio. Battery in a case with voltmeter is common but step up to a battery monitor. Now you'll better understand that the RV system depends upon you to best supply the solar requirements. It's common for someone to start with a smaller system and keep expanding.
I plan to install Solar in my new rig (Shopping now) and I also want to establish a 2nd and independent system for my Ham Radio operation. I want to be able to take my portable station out away from the rv and run it while operating ham radio, you guys who are hams will understand.
Install this battery monitor for $44 with a 350A shunt in the new rig to really understand your RV usage with some typical camping. https://www.amazon.com/AiLi-Battery-Monitor-Voltmeter-Motorhome/dp/B07CTKYFTG?th=1
As a ham most likely you will quickly understand and focus what you need/want. As I posted a battery monitor was my first purchase for the RV. I've never regretted that and I jumped to 750W, serial connected panels, raised panels for better shade tolerance and MPPT controller. I definetly didn't want to follow many prior installs with 12V panels and PWM controllers.
73's W7BE Bob
