โAug-20-2015 09:25 AM
โAug-21-2015 03:40 PM
โAug-21-2015 03:27 PM
pnichols wrote:First OP needs an air conditioner....
You might be thankful you had a genny along then ... for both battery charging and air conditioning in the potentially warm and humid conditions. ๐
โAug-21-2015 03:16 PM
Ace! wrote:
From what I gather though, my conditions will provide much less solar energy for the panels than someone in So Cal. It still may be overkill though.
โAug-21-2015 03:08 PM
smkettner wrote:
Worst case you roll out.
โAug-21-2015 01:19 PM
โAug-21-2015 01:16 PM
Salvo wrote:
Not sure you need that much solar. I've been using 130W for 8 years. It's adequate for us. The 2 x 6Vs (220Ah) are in absorption by 1 pm.
It's important to have a balanced system. 400W solar and 220AH battery capacity is not balanced. There will be a lot of wasted solar energy. You'll need 440 AH.Ace! wrote:
Thanks. I've been able to mock up a 400 watt system which should be in the $1,200 range and I can buy a sub-$1,000 generator too. I guess that should put me in a good position for a week or more without shore power...or at least I hope it will.
โAug-21-2015 01:02 PM
MEXICOWANDERER wrote:
Prepare for the worst...
โAug-21-2015 12:53 PM
โAug-21-2015 12:17 PM
โAug-21-2015 12:15 PM
โAug-21-2015 12:08 PM
Ace! wrote:
BTW, I don't have a microwave or A/C; although I am considering a television.
Can someone check my math. If a 120V television has an energy consumption of 25W, is that about .2 amps? Seems like the draw would be higher than that.
โAug-21-2015 09:00 AM
โAug-21-2015 08:56 AM
PFitt wrote:
Read up on Handy Bob's Solar blog. Everything you need to know on solar, batteries and best equipment to use. He's off-grid fulltime!!
https://handybobsolar.wordpress.com/
โAug-21-2015 08:52 AM
โAug-21-2015 08:34 AM
