Hi Snowman,
The reason I chose UniSolar was because it had no glass. When I purchased them they were $5.50 per watt. That meant going with the Blue Sky 3024di MPPT to grab every erg of power I could.
My system is serials parallel and by happenstance works better than my wildest dreams.
When/if I add 800 more watts I'll be considering poly, but size will definitely be an issue.
Snowman9000 wrote:
At rated watts, your panel makes 2.4x the watts per square inch of what the Unisolars do. I would like to know how they compare per square inch in the shade. I am doubtful the Unisolars regain the advantage on that basis.
