Passin__Through's avatar
Sep 16, 2016
Solar Panel Wiring
Is regular automotive primary wire suitable for use between a solar panel and the charge controller? I am installing two, 100-watt poly panels on the roof of my 5er, running the wires down a holding tank vent pipe, then to the controller. My plan is to wire the panels in parallel, then utilize the 10AWG automotive primary wire after the Y-connector.
My thinking is that automotive primary wire would be easier to work with as it is more flexible than the wire coming from the solar panels. It is also much less expensive than solar panel extension wire. I am aware I will need male and female MC4 connectors for the primary wire.
I have never done this before, so thank you in advance for your sage advice.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
