hmalaga
Dec 03, 2019Explorer
Solar power battery novice question
I recently purchased a Used Fox mountain by Northwood that has solar power using Go Power equipment. The control panel allows you check battery status by pushing a series of buttons to scroll thru it’s status. The panel directions say that it can be wired to show status of two individual batteries. My panel does not show status of the second battery. Trailer has two interstate 12 volt batteries wired in parallel. The panel says battery is at 100%. I have checked both batteries with my multimeter and they are both charged. So I figured I should check the control panel to see if the option for second battery readout was wired for the second battery. I have not done that because I started wondering if the fact that the two batteries were wired in parallel was simply allowing the solar to charged both batteries as if they were one and thus the read out at 100% was a reflection of the two? I am not an electrical guy and am limited in my knowledge of solar in general. So is my thinking totally missing the mark with my parallel charging theory or not? Thank you for any guidance or insight you can provide.
