โNov-10-2016 01:04 AM
โNov-12-2016 07:58 PM
โNov-12-2016 07:40 PM
โNov-12-2016 06:51 PM
TxGregory wrote:
And for that matter if someone turned on the Air conditioner, it would trip the inverter. Oh, and there is the microwave. . .
Whereas, if I go with something that will put out close to 30 Amp, 120 volt, then I would not have to be so careful. . .
I used to design and build IT, and we always had to be careful about bottlenecks. I don't want my inverter to be a bottleneck. . .
I saw a post from someone with a configuration similar to mine and that is what they said their did. If I am wrong, I would sure like to find out before hand! ๐
โNov-12-2016 04:01 PM
โNov-12-2016 03:18 PM
TxGregory wrote:
12gen,
I am with you. I would like to go with a smaller inverter, then I could stow it in its own battery box with the controller. But If I did that, I would have to be really careful about what I plugged into my abundance of AC outlets in my trailer. And for that matter if someone turned on the Air conditioner, it would trip the inverter. Oh, and there is the microwave.
Whereas, if I go with something that will put out close to 30 Amp, 120 volt, then I would not have to be so careful. (my controller supports 4X100W panels). I plan to add a couple of more batteries and panels in the future. So I am thinking that making everything capable of supporting 30 Amp 12 Volt will be a better solution long term. I used to design and build IT, and we always had to be careful about bottlenecks. I don't want my inverter to be a bottleneck. Now my assumption has been that if I had the 3000W inverter plugged into a 12v 100amp/hour deep cycle rv battery ... and I ran the Air Conditioner, that it would drain the battery and do no harm. I saw a post from someone with a configuration similar to mine and that is what they said their did. If I am wrong, I would sure like to find out before hand! ๐
โNov-12-2016 12:56 PM
Sam Spade wrote:BFL13 wrote:
My question then is, " How long can you leave it at 14.7ish before making it drop to Float at 13.7ish ?"
--And, how can you tell when it is time to drop to Float so you don't dry out the AGM?
AGMs don't "dry out".
And anyone who has to ask the first question should trust an automatic charger to do it FOR them.
Most people are not qualified to do it manually......including some of those who think they are.
โNov-12-2016 12:32 PM
I'm not suggesting "whole house" isn't a solution for some but there is more to it than just plugging the trailer's main service cable into the inverter.
โNov-12-2016 11:44 AM
SoundGuy wrote:
The better solution is to either hardwire the inverter .............
I did, and now when I lose power in the middle of the night all I have to do is
Sam Spade wrote:
The MUCH better solution is to run critical systems directly off the batteries or a small full time inverter.
That's what I do and now if I lose power in the middle of the night I have to do.......EXACTLY NOTHING. :Z
โNov-12-2016 11:37 AM
TxGregory wrote:
I am planning to have one battery for the controller, inverter... and another battery for the stock connection to the trailer. That way I would not have to turn off the converter to use the inverter. Where did you put your inverter? I am having a hard time finding a spot for mine.
โNov-12-2016 11:29 AM
โNov-12-2016 11:23 AM
โNov-12-2016 09:57 AM
I am planning to have one battery for the controller, inverter... and another battery for the stock connection to the trailer. That way I would not have to turn off the converter to use the inverter. Where did you put your inverter? I am having a hard time finding a spot for mine.This a poor design as you will get more power from multiple batteries connected. One single battery for inverter power is also a poor choice, mainly for the reasons in my post above.
โNov-12-2016 09:53 AM
โNov-12-2016 09:42 AM
SoundGuy wrote:TxGregory wrote:
Right now I am planning on a solar panel starter kit that includes a controller, a separate battery, a 3000W true sine wave inverter connected to the separate battery, and an extension cord plugged into the shore power outlet when I am parked.
WHY such a large inverter when just one battery won't be anywhere near enough to power it to it's full capacity? :h Keep in mind also that while powering the trailer "whole house" can work it does mean you have to be careful to always first turn off the converter and ensure anything that may otherwise be set to run on 120 vac is either switched off or switched to run on gas mode only. Also, whenever running on battery power alone make sure the fridge climate control is turned off, otherwise you'll be wasting valuable battery reserve. Unfortunately, some fridges don't offer this option, in which case it would be wise to add your own switch just as I did.
