Solar Rv awning -- does it pencil out?
profdant139
Great idea, but at ten thousand dollars for a thousand watts, I'm not sure it is worthwhile for me:
Article
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
25 REPLIES 25
pianotuna
Nomad III
Nomad III
$10 per watt=ridiculously expensive.
Regards, Don
Timmo_
Here is a link to Solar vs Honda financial breakeven analysis that will help determine which source of power is cost effective. This analysis indicates for the Honda 2000, it will take about 5.5 year breakeven, or around 1954 days of usage.
https://www.nroa2003.com/download/Miscellaneous/Cost_of_Solar_vs_Honda.xls
Of course the breakeven analysis for carbon emissions is a different story all together. At what point does the accumulated emissions from the generator's manufacture and operation match that of the solar panel emissions? If we take a page from the BEV's breakeven analysis, then it probably is several years away for heavy RV users and probably never for the occasional weekender.
Tim & Sue
Hershey (Sheltie)
2005 F150 4x4 Lariat 5.4L 3.73 Please buy a Hybrid...I need your gas for my 35.7 gallon tank!
2000 Nash 19B...comfortably pimped with a real Queen Size Bed
Danieljason
Can I install a solar awning on my Ford E-Series Van? Is the power it generates significant? Need advice! Thanks!
noteven
The Everlanders on you toob and the web doubled their panel capacity on a truck camper by using a slide system to deploy panels to the sides of the fixed set. They also shade the sides of the camper somewhat. They retract automatically if you forget when you go to move the truck.
The system uses conventional rigid panels and common rugged commercial parts.
valhalla360
Nomad III
Nomad III
Dusty R wrote:
Is there anyway of knowing how much power you can get from a solar panel in a given area ?
Sure, there are maps you can look up that estimate output when coupled with the panel ratings.
This thing though is a joke. Much better options...especially when it negates having an actual awning.
The roof is the logical first place for panels and after that smaller rigid panels that fold down to the sides would be a smarter option...and much cheaper.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Skibane
Lwiddis wrote:
and there’s no charging when rolled up while driving or during windy days.
You get charging-while-driving from the engine in the tow vehicle or motorhome anyway - so that's not a "problem" that this "solution" solves.
Basically, they took all the problems inherent in solar systems - and then added a few more by throwing an awning into the mix.
Do Not Want.
time2roll
Skibane
All 3 of the pictures in that article show the awning in shade - where it produces almost no power.
And in the real world, that's going to be a very common problem: Most campsites are shaded, because that's what campers want.
Shaded campsites produce little or no solar power.
And even if you're willing and able to park your RV in direct sunlight, you'll still have to deploy the awning to get any power out of it - in contrast to roof-mounted panels that produce power any time there's unshaded sunlight available.
Michelle_S
On our Winter Florida site, our awning faces North while the Sun is on the South side, so wouldn't generate anywhere near max.
While a neat idea, not overly practical in most cases.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Dusty_R
Lwiddis
Not in my opinion and there’s no charging when rolled up while driving or during windy days.
