MURPHY55347
Jan 13, 2019Explorer
Solar trickle charger
So I'm using a Battery Minder 20 watt solar panel to keep the batteries topped off. I'm tying to figure out if it's working correctly. It's partly cloudy today and I'm reading 13.25 volts from the solar panel going into the controller. But coming out of the controller and going to the batteries I'm reading 12.5 volts which is exactly what the batteries are reading. Coming out of the controller I'm using a splitter with one leg going to the starter battery and the other is connected to the both of the coach batteries. Battery Minder says I should be able to charge 4 batteries. The starter battery is completely isolated using a manual battery disconnect. This is a class A motorhome. It just doesn't seem like there is enough oomph to do the job. The other issue I'm dealing with is I'm questioning the integrity of the batteries. We purchased this motorhome new last May and I know it probably sat on the lot for a year before we bought it. Stater battery for one just doesn't seem to want to hold a charge but in the same breath I'm not sure the solar panel is doing its job. It's the middle of winter here so not much fun trying to do anything with it being cold out. I know I should have the battery tested but the other 2 batteries have to come out first and the starter battery weighs 46 pounds which is difficult for me to handle.
So to sum it up I have 2 questions.
Is the solar panel working correctly?
Can all the batteries be toast having been probably sitting in an uncharged state?
