Solar
Colo_Native
I am getting ready to install solar system on my new to me DP I am looking at 2 255 watt Sainty Solar panels off craigslist here. I am considering using a renogy 40 MPPT rover elite controller. I put a system on my old FW and I went all out on that but trying to save a buck. II also have a question about installing on a fiberglass roof(Winnebago) do I use screws and Dicor or 3M tape and some dicor? I went to look in the archives for my old system but it has disappeared from here. The MH already has a Magnum Inverter installed. As always thanks for the help
2015 Winnebago Forza 34T
pushed by a 2011 Fusion Hybrid or 2020 Escape Hybrid
Retired DFD
38 REPLIES 38
Colo_Native
2oldman wrote:
Colo Native wrote:
Also on the batteries I have 4 12v is the pos hooked up at one end and neg to other? It's been awhile since I did solar.
How is your converter hooked up?
Not sure what you are asking.
Retired DFD
Colo_Native
MEXICOWANDERER wrote:
Colo Native wrote:
Lwiddis wrote:
“The panels are sitting in a guys garage...”
Not comforting. You need a heck of a discount from him.
they are new never used and he wants $180 for each which I think $150 would be fair. But I will run a volt test to make sure
AMP TEST
SHORTED + to -- not connected to anything.
Mere volts will tell you nothing.
Already bought the 300w panels and they test fine.
Retired DFD
Colo_Native
time2roll wrote:
40 is fine with 600w of solar.
Good to know. Thanks
Retired DFD
RJsfishin
Sounds like you are describing series hookup wich would be 48 volts.
Rich
2oldman
MEXICOWANDERER
AMP TEST
time2roll
Colo_Native
Ok I found 2 brand new 300w panels for $300 so I went with them. I am thinking now that I should go with a 60 amp controller or would a 40 still if I remember the 40 had a 600w max. Also on the batteries I have 4 12v is the pos hooked up at one end and neg to other? It's been awhile since I did solar.
Retired DFD
Colo_Native
they are new never used and he want $180 for each which I think $150 would be fair. But I will run a volt test to make sure
Retired DFD
Colo_Native
My old system on the FW was 510w solar with a 45 amp tristar and it worked fine. I agree with them laying flat I doubt they would over produce the controller.
Retired DFD
BFL13
Using 7 flat vs 8 aimed ratio (based on some tests I did in May at 49N)
for amps output at high noon starting with aimed--
510w with 10% heat loss = 459w with say 2% line loss array to controller= 450w input with say 5% controller loss = 428w output. Amps to battery is output watts/battery voltage, so: (with no line loss controller to battery)
428/12.5 = 34.2a and 7/8 of that is 30 amps estimated
428/13.5 = 31.7a and 7/8 of that is 28 amps estimated
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
time2roll
KD4UPL wrote:
Sorry guys. I had a typo with the 310 watts, it's obviously 510 watts of PV, But the amps is still the same: 510 watts / 12 volts = 42.5 amps.
40 amp MPPT is perfectly good for this set-up. Actually a 30 would be fine. Only very rare conditions would produce close to 40 amps.
2oldman
510w of solar will rarely if ever hit 510w. Maybe 400.
KD4UPL
