BFL13
May 21, 2021Explorer II
Usually on here they say to jumper/by-pass the ATS to see if that is where the fault is. You only need to do that with the generator side.
If that works, then you could do PT's idea and have manual switching between shore and gen. If you get an inverter you will need to do that manually. With a portable gen you do it manually between the three 120v sources. You don't need no steenkin ATS.
