MEXICOWANDERER
May 25, 2021Explorer
I like to clean my relays then saturate a Q Tip with spray silicone lube.
I dab the lubricant onto hinge points and work the mechanism several times. 30 amp DPDT relays are hard to find down here and when one is found the price weakens my knees.
Also on critical stuff I'll wipe DeOxit D100 across contact points.
Special attention goes into making the relay enclosure moisture-tight.
