โJun-29-2013 03:17 PM
โJul-07-2013 06:41 PM
Almot wrote:I keep saying this but the 12V TV crowd never has a response. I have yet to see a 12V TV draw LESS power than my off the shelf, 26" Vizio. If there is a 12V 26" LED LCD that draws less than 2A DC, I'll STFU about it.
Other than small-screen automotive market, there isn't much demand for 12V powered TV. Recent 27" LCD/LED models draw less than 3A @12V.
โJul-07-2013 01:07 AM
pnichols wrote:
Use an inverter occasionally for the microwave if you don't want to use the big generator or don't have air conditioning (hence no big generator). By the way, 12 volt microwaves do exist if you want to hook them up via big cables directly to your RV's battery bank.
pnichols wrote:
Regarding "lousy 12 volt powered" TVs. We have a superb 26 inch LED TV that "seems to" operate from 120 volts AC, but ... actually uses an external brick to make this happen. The brick merely changes 120 Volts AC into 18 volts DC for the TV's circuits. If I change out the brick that came with it for a 12 volt DC to 18 volt DC upconversion DC-to-DC upconverter brick ... then I have a superb "12 volt" TV without suffering the losses from using inversion to make 120 volts AC out of 12 volts DC.
โJul-06-2013 12:38 PM
โJul-06-2013 10:20 AM
โJul-06-2013 09:10 AM
pnichols wrote:Nice picture! I'm not sure a 24ft MH has appreciably more room than an Eagle Cap 1165. Probably more storage though. Also, can't tow my horse trailer with most Class C's. I looked. Was VERY hard to find a 5000 lb tow rating on one and none of the new one's I saw had that capability. DW would never give that up (and why should she). With a TC and a F550, I can tow 14,000 lbs. There's a lot of flexibility there. I can pretty much do what I do now and then some. Even if my MH was fully loaded to GVWR, it has 5500 lbs between that and its GCWR. It can, and has, easily towed our horse trailer. Towing the horse trailer is a requirement.
Just as a datapoint on what's possible with a small Class C (although on the E350 chassis in this example) ... here's a 22 foot Itasca Spirit owned by EMD360 and this is a partial quote of his from another thread on how he uses it:
"We love the short length and have taken it on many an AZ dirt road. We use "training wheels" to keep from losing anything underneath although we lost one set of those wheels and the steps on a particularly rocky unpaved road. We do the repairs and go back out again.
We typically go from 3 to 10 miles off the paved roads to find seclusion and have never tried to tow."
Soo ... a TC may not be required for adventures offroad while still maintaining superior comfort, room, and stability. Here's a photo of a typical road we sometimes find ourselves on with our 24 foot Itasca Spirit:
โJul-06-2013 08:30 AM
โJul-06-2013 06:52 AM
โJul-05-2013 11:50 PM
โJul-05-2013 11:02 PM
westend wrote:That would be fantastic but it would see very light duty use in my care.
You guys need to get styling with the Unimog. 30 degrees of axle articulation so pile the weight on...:B
โJul-05-2013 08:12 PM
โJul-05-2013 05:43 PM
โJul-05-2013 03:44 PM
โJul-05-2013 02:41 PM
pnichols wrote:Eagle Cap. Three slides, kitchen island, large FW tank (80 gallons). Looks like a decent amount of outside storage too (would have to see one to know for sure).
What TC would that be??
pnichols wrote:Money and parts can fix stability issues, if it's really an issue, and we're still pretty young so no worries about the stairs. I've looked at Tigers and the only problem with them is no bed. We have horses and need a bed for hay and other stuff. Also, Tigers don't have the FW capacity I want. I like not having to worry about water. We have a 75 gal FW tank and there's plenty for two showers each plus dishes and cleanup after a 3 day trip. Have yet to run out. I would consider 75 gallons to be minimum. My goal is to have a bad ass boondocking setup where we can go a month at a time without dumping or hooking up to shore power. Of course, a month long trip would be in retirement but I want to figure it all out by that time.
Those step-height and center-of-gravity issues are why I consider the ultimate go-anywhere-in-complete comfort (affordable) RV to be a Tiger chassis-mounted coach built unto a 1-ton 4X4 pickup.
โJul-05-2013 01:45 PM
mena661 wrote:
A little OT but I "discovered" a TC that eliminates all I don't like about TC's.
โJul-05-2013 12:54 PM
pnichols wrote:Very true. You get no arguments from me here! A little OT but I "discovered" a TC that eliminates all I don't like about TC's. Too bad I already bought the MH. Still love the MH though.
You're less stressful concerns over camping electrical power are probably pretty common for us motorhome owners with our easy-start, easy-fuel-supply, built in generators and main engine alternators full-time-connected to our coach battery banks ... regardless of whether or not us motorhome owners have particularly huge battery banks or whether or not we have solar arrays on the roof. It's the pop-up trailer, regular trailer, fifth-wheel, and truck camper owners that as a rule have the hassles with storage, set-up, and securing of separate generators and the fuel supplies for them - especially if they don't have solar arrays at all ... or large enough solar arrays.
To camp in a low stress power source way, we know that if push comes to shove we can in any weather just push a button to start the Onan connected to a 55 gallon fuel tank or quietly idle the V10 connected to the same 55 gallon fuel tank. That's one reason we bought a motorized RV instead of a towable - convenience. We have a minor hassle in that we use a very small super-quiet generator to replace solar panels. Now ... if only we could reach the same camping spots as a TC can ...
pnichols wrote:Like the idea of those fuel cells but the expense makes LI customers cringe. :B I'd rather have a fuel cell than solar honestly. Hopefully prices will come down in a few years.
I suppose the ultimate non-hassle power sourcing setup for any weather any time drycamping is a well-installed, quiet, large built-in generator for air conditioning, a large battery bank, and a 24/7 automatic battery-top-up fuel cell so that having the sun is of no concern/worry. This is an expensive arrangement, though. ๐
