jaycocreek
Sep 09, 2022Explorer II
Can the Renogy 30A PWM charger charge both the AGM batteries and LiFe battery at the same time?
I have a Renogy 30A PWM connected to a single 100AH LFP with aligator clips so I can charge whatever battery or bank I want..I use this particular battery for coffee maker/microwave and hot plate and kept close to fully charged,it does the job..If I need more charging of something else.I just use the aligator clips on that battery bank...Weird maybe to some,but it works for me..
So,yes you can use that controller on two different battery banks independently, but not at the same time with alligator clips or by just changing which batteries are connected to the Renogy.
Good luck..
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
