theoldwizard1
Jul 01, 2019Explorer II
While I have had to deal with failing lug nut "covers" I am not sure that is the OP problem. The bore where the stud is pressed into from the rear of the drum/rotor look too smooth. See how deep the knurling is on the stud. It looks almost gone on the bore. Loctite make a special adhesive just for something like this, Loctite 668 High Temp.
(My guess is that someone over torqued the nut to begin with and the knurling failed
Good drill bits, lifetime guarantee - Drill Hog 21 Pc Drill Bit Set w/Index
