chilly81
Aug 06, 2014Explorer
Split battery bank to multiple locations?
I can get 2 6V golf cart batteries on my tongue in the stock location. If I want to double that, I'm pretty limited (nash 22H 22' TT).
One of the options I was wondering about was leaving the existing 2 tongue batteries, in series together for one 12V unit. Then adding 2 more on the rear bumper - also as a 12V pair.
My electrical 'hub' (header, fuse panel, converter tie in, etc) is around mid-trailer. It has a stock 6AWG 10-15' run to the battery. So I'm wondering....
Assuming both banks get wired in parallel to the same header, then I know that simplistically it's the same wiring diagram. But what about reality? Assuming I will match the impedance of the runs. Are there issues with them having separate grounds to the trailer frame? Are the other issues that I'm not seeing?
