Spray Foam Sealant
phurley
The local RV repair shop uses Touch N Foam Home Seal for holes that didn't quite get filled at the manufacturer. Is there another brand that anyone can recommend? I can't get Touch N Foam Home Seal on Amazon and the local hardware store doesn't have it.
2007 Rockwood 2601
2003 Niagara
Ford F250
8 REPLIES 8
David_R
spadoctor wrote:
great stull also has one now that repels bugs and rodents
I've not seen that one, I'll look for it next time.
2007 BT Cruiser 5231
2002 Heritage Softail Classic
spadoctor
Bumpyroad
not just appropriate for the size of holes, for the effect that extreme swelling might be, pushing out side paneling, etc.
bumpy
We_Cant_Wait
Great Stuff has several different products, the normal expanding (2x), a minimal expanding foam, and a 3x expanding foam, use the one appropriate for the size holes you have to fill.
Bumpyroad
there are at least two varieties, on that doesn't swell up quite as much.
bumpy
nineoaks2004
If you use it, remember, that stuff swells up a lot bigger than you think.
By the time you learn the rules of life
You're to old to play the game
David_R
I have been satisfied with Great Stuff from Home Depot to seal gaps at home and in our RV.
Executive45
Check HERE.
Not sure if it's approved for sale in California though...pretty nasty stuff if you read the MSDS sheets..and you know how California is with "dangerous" stuff....Dennis
On edit: it appears it's available at KMart stores in both NorCal and SoCal..according to their website....Dennis
