Start Issues
Teranza141
Trouble starting 1997 Ford E350 Class C. Loose all power when trying to start engine. Able to start using emergency start switch. Both van and house batteries fully charged. Everything works once running. Any clues?
2 REPLIES 2
Grit_dog
Navigator
Navigator
You said start battery was fully charged, but do you know it’s actually good?
bad start battery or poor connection. Then once started the alternator is covering for the issue.
Krusty
Nomad II
Nomad II
Does this mean that all the warning lamps etc are on when the key is in the RUN position, then when you turn it to the crank position, everything goes out and it doesnt crank? When this happens it is typically caused by a loose connection. If it will start using the emergency start switch, you should check the main (starting) battery for loose or corroded connections.
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
